I got some clear vinyl tubes and it says the tubes can be used for chemicals, gases (like air), and greases but can it withstand gasoline? Will it be alright to used it to connect gas tank to the carburetor?
It's good to be the king
A vinyl tube? Vinyl is used on car interiors and stuff like Rob's love doll girlfriend. :D
I'd just run down to the auto parts store and get a rubber piece of hose if I were you. ;)
Deuce
Discussion Starter #8
Money is not really the issue, I just want a fuel line that is clear. All I can find as of this moment is black ones... any suggestions on where I can get clear fuel lines that's specially made for that purpose?
Clear tube should last a while. There are thousands of variants, so expect some defferences in performance. If it's important to you to have clear tube, just make it a regular maintenance item to replace about every year.
