You'll never really be able to smooth it out well. Our suspension has way too much low speed compression damping. This makes it feel very harsh over sharp bumps.
Almost impossible to dial it out without the bike getting wallowy and slushy feeling.
Do you have the correct sag adjusted (spring preload)? At your weight, you should be within the front springs range and maybe a little oversprung out back.
Get that done and then play with the adjusters and keep notes while doing it.
Cheers, Lee S.
Cheers, Lee S.
