I saw an article in a recent issue of a motorcycle rag that was interesting. But the author was either confused or he was simply a moron. Maybe you guys can clear things up for me.
It concerns the "code" that's imprinted on the sidewalls of every tire.
It'll be easiest to work with an example: 130/70R17 H 62
Here's what I'm sure of:
130 = width (in mm) of the tire
R = Radial
17 = size of rims the tire fits onto
H = "H" rating - for sustained 130 mph
Here are 2 things that I'm not so certain of:
62 = load at maximum air-pressure
I understand that "maximum" air-pressure is NOT the recommended air-pressure at which the tire should be run. But what exactly is that 62 supposed to tell me?
70 = aspect ratio (in percentage) of the height of the tire in relation to the width... right? If'n that's so, then the actual height of the sidewall of this example would be 70% of 130 = 91 mm... right? But the author goes on to say that the 70 means that the tire's sidewalls are 70 mm tall.:confused If'n that's true, then the 70 is simply a straight-up number, and NOT a ratio. But the author contradicts himself and says that it is a ratio. So... which is it?
Oh, and another tidbit of interesting info: every tire made after 2000 has a four-digit number imprinted on it that represents the date of manufacture. The first 2 digits denote the week and the last 2 digits denote the year.
R = Radial
