I don't know anything about your problem but I should maybe look into it. I seriously think I have sleep apnea though.
Thats a bit diffferent though, usually deals withthe throat, I have a friend who had it prety bad and had the surgery, she said it took a while for her to re learn how to swallow foods and liquids. I may look into it myself since I do have a few of the symptoms.Rue said:I don't know anything about your problem but I should maybe look into it. I seriously think I have sleep apnea though.
which surgery Tom?? Were you referring to the sleep apnea?tommymac said:Thats a bit diffferent though, usually deals withthe throat, I have a friend who had it prety bad and had the surgery, she said it took a while for her to re learn how to swallow foods and liquids. I may look into it myself since I do have a few of the symptoms.
Tom
Well... I've had to re-learn how to swallow once already. We discovered after having braces on my bottom teeth twice that I was swallowing wrong. I had no idea that was possible in the first place.tommymac said:Thats a bit diffferent though, usually deals withthe throat, I have a friend who had it prety bad and had the surgery, she said it took a while for her to re learn how to swallow foods and liquids. I may look into it myself since I do have a few of the symptoms.
Tom
The throat surgery, her throat was widened by about 60% which is apparently quite a lot.k9zgirl said:which surgery Tom?? Were you referring to the sleep apnea?
Based on where you put your tongue. Typically when you swallow "correctly" you put your tongue on the roof of your mouth. I used to thrust my tongue forward against my teeth.Jeff6R said:How is it possible to swallow wrong? :confused What's different between the right way and the wrong way?
I don’t think so… they just rotted out their noses.ScottyCoyote said:isnt deviated septum what alot of people who did coke and stuff have?
A deviated septum is when your septum (cartlige that seperates your nostrils) is over more to one side than the other. Its a natural thing. The coke thing actually like mentioned by Rue, is a hole in the sinuses or septum from snorting coke. 2 different thingsScottyCoyote said:isnt deviated septum what alot of people who did coke and stuff have?
I agree 100%Dvus3000 said:
I've had the surgery. It's a relatively quick day surgery. you have tubes and packing in your nostrils and trust me when they say to breathe out of your mouth when you come to from being under. You better do it.
As for pain. This is none to be the worst recovery and most painful. The key is to get all the pain killers as many as you can before your morphine wears off.
Always stay on top of the pain. Vicodine every 2 hours is a must! Always take your anti-biotics. If you do that you won't feel any pain of course you'll be all high, but that is much better than feeling an ounce of pain. DO NOT MESS WITH YOU NOSE TOO MUCH DRAIN IT WITH SALINE! If anyone messes with your nose you will definitely feel it.
As to breathing and sleeping good luck! After the first night, my mouth was drier than Death Valley. I drank water but not too fast cause I couldn't breathe out of my nose. I couldn't sleep cause I had to breathe in and out of my mouth and had to be propped up. Eating right. You cannot taste anything since your nose is in no use. Bland and only feel textures. So don't go and spend too much on fancy foods.
It takes about 2 weeks and once my vicodine was all gone my nose was in pain. Try to get 3 to 4 bottles of vicodine. It will be worth it.
After my recovery, the doctor removed the tubes talk about more pain. He removed the stitching and the packing came out. Blew my nose and some horrid foul looking chunks of paking that looked like liver came out. OUCH!!!!! I had mine done in the winter. After the visit I felt the coldest air! Talk about brain freeze DAMN! But the air smelt sooo fresh it was great.
I had packing stuck in my nose for 2 weeks!
I feel sooooooooooooooooooo
Much better. No more sleep apnea and no more closed nostirls during allergy season. I can breathe much better. I'd do it all over again with out a doubt!
