I took off the front end to replace the stock signals with some LP short stalks. By mistake I reversed the running light and ground connections and it would not work correctly. When I reconnected the signals properly I tested them and everything worked, I was also able to crank the engine.
Now, when I turn the kill switch ON the FI light is not coming on, it does not even blink. I also cannot hear the fuel pump activating
What could be wrong? I checked all the fuses and they are okay.
Any thoughts on this? Thanks!
