1 - 14 of 14 Posts
does this just mean you just counter steer harder and faster to make the bike lean over quicker?
Rollin' & Trippin'
:lol You guys are :nutz :lmao
Another Hit of the Track Pipe Please!!
ZxHunteR said:
It means get rid of the booger on your gloves quick here comes a turn!
:crackup :laughing :crackup :laughing :crackup :laughing :crackup :laughing
I take it to mean how fast a bike can lean over, where it's most evident is going from leaning one way to the other, in a chicane for instance.
Also don't forget you can also weight the peg on the side you want to lean to (the new inside peg), and that will also make it lean faster.
Doin' the things a particle can...
I thought it meant giving the :doublefli to the soccer mom that almost ran you over
:D
You can keep your CHANGE
I think applying pressure on the pegs is mroe effectivie :) maybe that's just me
Support TC or fly like a fairy!
:lol:crackup That's some funny sh!t
thrain said:
i always heard to put your weight on the outside peg
Riding dirt bikes? Yes. Streetbikes? No. On a dirt bike you do it to keep the tire digging into the ground. On a streetbike you don't have to worry about such things (unless you PLAN on spinning up the rear) so just weight the inside peg to help turn the bike.
Check out Nick Ientsch's Sport Riding Techniques at the bookstore.
True about dirtbikes, but not with..racebikes. The way to turn it, is only with countersteering...the harder the faster. Using the inside peg helps the transition effort, but when getting on the gas you wiegh the outside peg for the same reason as you do on the dirtbike...
Granted about countersteering, I'm just assuming everyone does that because you can't really ride a bike without it. Also if you're getting on the gas then that means you're beginning to exit the corner and need to stand the bike up. Thats just what I've found, I haven't gotten to the point of needing to weight the outside peg to keep the back end from stepping out.
1 - 14 of 14 Posts
