how do i check the float level height and then after that how do I set it???
i have the service manual... but is this the way to do it??
reinstall the floats and set the float bowl height. I found this to be the most nerve-wracking as it seems very imprecise and the actual method of adjustment is "jicky". I really couldn't understand EXACTLY what I was supposed to be measuring until I found this pic on Factory Pro's site: www.factorypro.com/images/carb,float adj,38Mik.jpg AHA! Now it all made sense. Also notice that the carbs are being stood on end to measure. I did this also and it seems to work ok although I measured the floats w/ the carbs lying on the bench as well. I didn't have the Factory Pro tool, but thanks to Suliman, I ran out and bought a $20 Sears Vernier's calipers w/ a depth measurement beforehand. Worked well. I just set it to 3.25mm and ran it along the surface of the carbs. If it came in contact w/ the floats, down they went. Much of a gap? Up w/ the floats. Not too difficult, just time-consuming to get just right.
