Back from the dead, this thread is.
For the gauges I make a piece of carbon fiber (aluminum or fiberglass or steel or plexi would work too) out of some scraps I had lying around. I drew out the shape I wanted and cut it all out with a scroll saw. I used misc bits of hardware from Lowe's to attach the Temp and Tach gauges. Just unscrew the speedo cable at the front wheel and put it on ebay. Affix your new gauge cluster with zip ties to your fairing stay, and ride!
The fairing stay is the race model from Vortex. But they don't make them anymore. GP Tech makes some though. Or you could go to your local welder/fab shop and have them make one for you. Should take about an hour. I'm looking into making one out of CF. If it works in real world testing I may make a few more.
The Steering Damper is a Sprint I snagged on Ebay for cheap. It has 14 clicks and seems to work fine.
The front brake lever/master cylinder is off of a 2000 ZX6R. The original was damaged in a previous crash and leaked a bit. $14 on Ebay.
If you look atmy last pic, just above the top of the fork tube is a cable. That is my choke. I just have to stand there and hold it open until the bike is warmed up enough to idle on its own. Not a problem here since really cold weather is rare in winter, let alone during track season.
Let me know if you have any other questions.
