OK - my ADVRider account is jacked up. Can't post. You want to ride the GS a couple hundred miles, bring the Busa. We can do that... no problem. Just say when, we both have lectrics.
As for maintenance. Valves take under an hour if you are quick, I'm not. I can still probably have it done in an hour. I know a lot of guys who check the valves less frequently than 6K cause they are in spec when they check at 6K.
Throttle body sync (there are only 2) takes 10 minutes. Due that every 6K if needed. Oil change is called for every 6K, I do mine every 3K and it takes 15 minutes.
Drain transmission and final drive fluid and replace every 12K. I switched to synthetic. Noticed smoother shifting.
No chain to lube, that's it. If you are serious I'll let you look at the factory manual with the service intervals in it.
Regardless, I want to ride the friggin' Busa !!!!!
The Duke II was a hoot - I need to build me a Motard soon.
Barry
