1 - 9 of 9 Posts
suzuki17 said:
Anyone no how to disable this on an '04 gixxer6?
weld the plunger in so that it thinks the kickstand is up :shrug
Super Moderator
yIf you are racing or doing trackdays where the stand HAS to be removed, you can bypass teh switch by putting a jumper between teh two wires. DO NOT TRUST DUCT TAPE to do it. Seen a guy on a TLR tape his shut and the tale came off mid corner and tossed him off.
the sensor goes off on hard accel. Also if I bounce up a wheelie. Maybe I just need a stronger spring.
Super Moderator
Sounds like teh switch is shot. Also you might wanna check to see if the tipover switch may be going goofy.
i belive on the gixxer you can just unplug it or maybe i cut the wire and twisted it together
its a little light green two wire plug should be under the tank down near the back of the engine hope this helps
i agree.....sounds like tip over sensor.
if the bike turns back on with out turning the key off and then back on its not the tip switch once the tip switch is activated you have to turn the key off and back on
1 - 9 of 9 Posts
