:laughingRedrider2k2 said:
Someone get a shot of Ceiling cat poking out of there STAT!
+1 wtf101Lifts2 said:
Isn't there a filter in the furance? I've never seen one in the duct like that...looks ghetto.
mmmmm. sawzall. my favorite tool.askmrjesus said:Oh, by the way, the correct tool for cutting that joist would be a Sawzall.
The Sawzall, however, is a dangerous power tool in the hands of a novice, so I don't recommend using one without first obtaining the proper training from the Power Tool Safety Foundation.
In the meantime, you could begin with a butter knife.
Remember: Start small! :nanana
JC
That's the intake duct that supplies air to the furnace. It's actually fairly common for the filter to be there.101Lifts2 said:
Just leave it alone, I'm sure that is not the only duct in the house. Your only gaining 3 inches by moving the joist.
And for God sakes stick your hand with a wet cloth and wipe out that duct ..looks nasty.
OUCH!:crackup :crackupaskmrjesus said:
This is why GM should not build houses.
JC
JC
right, GM that "nasty" stuff is mastic it's to seal the airbox so that air is drawn in only from thru filter.askmrjesus said:
Leaving the joist in the way restricts the airflow, and lessens the effectiveness of the filter.
JC
That's not a bad idea. It's not optimal, but it would help.RACER X said:
how about drilling some "big" holes thru the joist to "even" out the airflow or at least get some suction thru the other side. ala swiss cheese style.
yeah, new house, look at the filter only 1/2 of it is dirty, therefore the A/C unit is working 2x as hard to get the same amount of air. instead of a 20x30 filter it;s theoretically a 10x30.karl_996 said:
Is that in the new house?
I really doubt the wood will have an effect on the airflow.
It is way too low of a pressure to have the wood affect it.
The nails go through the plywood into the joist.RACER X said:
no, i would swiss cheese the joist itself.
