Im trying to change a rear tire on an ex500, and when I mounted the new one on, it doesn't turn more than a few degrees.
This is kind of hard to explain because Im not real mechanically inclined...but...
When I rotate the wheel, it seems that the bolts holding the disc brake onto the tire bang into the actual brake pads. I thought I mounted it the same way I took it off and the brake unit seems to be in the right place since the lower part of it fits into a kind of notch in the swing arm.
I can try to explain more, but Im sure that someone should be able to recognize the situation and point me in the right direction.
Thanks in advance for the help.
