1 - 3 of 3 Posts
· Master Debater
Any suggestions on how to remove the front brake lever on an F4i? do i have to undo the throttle cables first to get to the bolt?
· Registered
No, you dont have to undo the throttle cables to get to it. The easiest way is to get a small straight edge screwdriver to hold the screw with. Then get a socket and unscrew the nut on the bottom with.
I think its a 6mm nut on the bottom of the screw. After its loose, remove the screw and pull the lever off.
· Master Debater
thanks for the reply B
taking the 10mm nut off was simple didnt even need a screwdriver to do it. but putting it on i budged the throttle adjuster up a bit to get a regular size driver in there and then tightened the nut. I wanted to make sure i had enough leverage so i dont scratch or fook up anything. Was simpler thatn i thought it would be.
1 - 3 of 3 Posts
