1 - 3 of 3 Posts
CF hater....
Received a new sd card thru bjy .com
512mb
Took a few pics on it.
Then put the card in a card reader.
Tried to delete files from the card but I keep getting a message saying the card is write protected
What gives?
- The card is not locked manually( little slide is in un locked position)
- I tried to format it ( wont let me)
- rebooted , removed the card etc, same message,
whats the issue?
i need to free up space on the card.
For :shit and :citadel, did you try puttng the switch in locked position to see if somehow it was labeled wrong? The other idea I have is put the card in a unit that can do the formatting for you. I have an MP3 player that also is a USB flash drive.
It's a POS, but I made the mistake of formatting it from the computer. The thing didn't work worth crap, and I had to get the onboard software to "reformat" the memory before it would work as an MP3 player again. Maybe you could put it into a camera with onboard memory software and have it format the card for use?
CF hater....
thanks after rebooting for the third time... it worked.... thanks for the help though
1 - 3 of 3 Posts
