1 - 3 of 3 Posts
2008 harley sportster 883 spits and sputters in bumpy road at low speeds no back firing or smoke idols fine harley shop says they couldn't get it to act up after being in the shop for a month but I think they just couldn't figure it out driving down highway bike runs great but on a bumpy country road at low speeds bike runs horrible like something is loose I've changed battery checked ground changed spark plugs but still acting up someone please help
Super Moderator
Hello and welcome.
I'd check the ignition switch connections. If its an electrical issue, you will probably have to check pretty much every wire, connector and plug. Do you have a factory alarm? If so try disabling it and see if it still does it. Heard thats one of the things they do when they go screwy.
The shop you took it to an actual HD dealer or just a small repair shop that works on HD's?
Wish I knew more about them. If you noticed, not a lot of traffic here anymore. Have you tried some of the HD specific web forums like hdforums.com?
Discussion Starter #3
I'll check the ignition switch and thanks for responding and yes it was Roughneck Harley in longview tx
1 - 3 of 3 Posts
