1 - 16 of 16 Posts
I've noticed that a lot of times when going into a straight stretch of road that my throttle seems to hang wide open, sometimes i cant get it to let off till the end of the straight:confused anybody else have this problem?
this also happens when coming out of turns,
"RHC" 2nd in Command
I think that is a common problem with Yamaha's especially when they are following a 7fiddy.:redflip
Also try pulling the grip off and clean underneath on the clip on. I had this problem in the summer. Went through the trouble of replacing my cables when all I had to do was clean and lube up the clip on.
YZFRob said:
check the cable routing. Might be kinked.
:kickballs :slap
joke anyone?
Discussion Starter · #15 ·
gixxerman03 said:
im sorry you must be talkin to, opps im sorry i forgot that you arent anyones daddy. i think that you are the one that needs to put down the crackpipe cause its messing with your head.
the seafood has obviously eaten a whole in your brain, EVERYBODY knows that lil R1 is 98% of the time in front of that gixxer:nanana
1 - 16 of 16 Posts
