I just got this email from a coworker
I have given up on sodas and what not for good old water myself but thought this was a good read and wanted to pass it on.
> This is really an eye opener.... Water or Coke? We all know that water
> is
> important but I've never seen it written down like this before.
> WATER
> 1. 75% of Americans are chronically dehydrated.
> 2. In 37% of Americans, the thirst mechanism is so weak that it is often
> mistaken for hunger.
> 3. Even MILD dehydration will slow down one's metabolism as much as 3%.
> 4. One glass of water will shut down midnight hunger pangs for
> almost100% of
> the dieters studied in a University of Washington study.
> 5. Lack of water, the #1 trigger of daytime fatigue.
> 6. Preliminary research indicates that 8-10 glasses of water a day could
> significantly ease back and joint pain for up to 80% of sufferers.
> 7. A mere 2% drop in body water can trigger fuzzy short-term memory,
> trouble
> with basic math, and difficulty focusing on the computer screen or on a
> printed page.
> 8. Drinking 5 glasses of water daily decreases the risk of colon cancer
> by
> 45%, plus it can slash the risk of breast cancer by 79%, and one is 50%
> less
> likely to develop bladder cancer.
> And now for the properties of COKE
> 1. In many states (in the USA) the highway patrol carries two gallons of
> Coke in the truck to remove blood from the highway after a car accident.
> 2. You can put a T-bone steak in a bowl of coke and it will be gone in
> two
> days.
> 3. To clean a toilet: Pour a can of Coca-Cola into the toilet bowl and
> let
> the "real thing" sit for one hour, then flush clean. The citric acid in
> Coke
> removes stains from vitreous china.
> 4. To remove rust spots from chrome car bumpers: Rub the bumper with a
> rumpled-up piece of Reynolds Wrap aluminum foil dipped in Coca-Cola.
> 5. To clean corrosion from car battery terminals: Pour a can of
> Coca-Cola
> over the terminals to bubble away the corrosion.
> 6. To loosen a rusted bolt: Applying a cloth soaked in Coca-Cola to the
> rusted bolt for several minutes.
> 7. To bake a moist ham: Empty a can of Coca-Cola into the baking pan,
> wrap the ham in aluminum foil, and bake. Thirty minutes before the ham
> is
> finished, remove the foil, allowing the drippings to mix with the Coke
> for a
> sumptuous brown gravy.
> 8. To remove grease from clothes: Empty a can of coke into a load of
> greasy
> clothes, add detergent, and run through a regular cycle. The Coca-Cola
> will
> help loosen grease stains. It will also clean road haze from your
> windshield.
> For Your Info
> 1. The active ingredient in Coke is phosphoric acid. Its pH is 2.8. It
> will
> dissolve a nail in about 4 days. Phosphoric acid also leaches calcium
> from
> bones and is a major contributor to the rising increase in
> osteoporosis.
> 2. To carry Coca-Cola syrup (the concentrate) the commercial truck must
> use
> the Hazardous material
> 3. The distributors of coke have been using it to clean the engines of
> their
> trucks for about 20 years!
> Now the question is, would you like a glass of water or coke?
> is
> WATER
> almost100% of
> trouble
> printed page.
> by
> less
> two
> days.
> let
> Coke
> Coca-Cola
> is
> for a
> greasy
> will
> windshield.
> For Your Info
> will
> from
> osteoporosis.
> use
> their
