1 - 20 of 28 Posts
My computer is so ghey, it wont let me be on two message boards at once. Everytime i try it says there was an internal error and one of the windows you were using will now be closed. What the frick could be wrong with my computer? I have plenty of memory:confused
well we really need some more info....
when was the last time you rebooted?
Guess yo have a gateway LOL Mine is a major POS. Cant run a streaming vid with any player or the fawker locks and reboots.
Try updating IE or go with a different browser altogether, ive heard great things about Opera. Also whats your connection speed?
Discussion Starter #5
i have DSL and I update IE everytime its available. I reboot my computer everytime i get on it. It never stays on more than a few hours.
try installing a new copy of IE...
My pentium 200 runs like the day I bought it.. It might be slow, but, I've had it for 6 years or so and it's relatively trouble free...
Discussion Starter #8
does that mean delete what i have now and install a new copy?
you can't delete IE...
just get a new copy, and install over...
then plug in your upsdates...
if you could write down the message you get when the comp is crashing and post it here I could give you a better answer...
I also need the details on your comp...
CPU
operating system..
etc..
p.s. I need the message VERBATIM...
Discussion Starter #10
CPU
operating system..
etc..
next time it happens ill write it down
Discussion Starter #12
first a notice popped up and said:
Explorer
this program has performed an illegal operation and will be shut down
if the problem persists, contact the program vendor
and the details are:
EXPLORER caused an invalid page fault in
module EABH.DLL at 0177:020fba40.
Registers:
EAX=0020006d CS=0177 EIP=020fba40 EFLGS=00010202
EBX=80000001 SS=017f ESP=01c7f8a8 EBP=01c7f8c4
ECX=014c5257 DS=017f ESI=02288010 FS=119f
EDX=01c7f8cc ES=017f EDI=02292b1c GS=2dcf
Bytes at CS:EIP:
ff 11 83 65 fc 00 8d 45 08 8d 4e 14 50 e8 b4 08
Stack dump:
0020006d 02154990 01c7f8cc 02288790 01c7f8d8 021421a8 ffffffff 01c7f8e4 021145c3 00000000 02292ab0 02288010 01c7fcc8 02143eea ffffffff 01c7fcd4
then i get another notice that says:
There was an internal error and one of the windows you were using will be closed
you can just go to your add/remove programs and click on IE and then hit repair too...
or you may need to repair the registry also... if you are in WIN 98 boot to a c: prompt and type in scanreg /restore
Discussion Starter #16
ZoomByU said:
thanks man, i have kazaa so that makes sense. Thanks alot im gonna go it now
try kazaa lite...
much better than normal kazaa anyways, and no spy-ware...
also..
http://www.webattack.com/get/adaware.shtml
install that and run it, will get rid of any crap you didnt know you had..
lemme know how this all turns out...
Discussion Starter #18
i unistalled it and restarted my computer but now it says to open a dos window, do i have to restart in DOS or can i just open a window? If i have to restart in DOS how do i get back into windows?
it says to open a dos window?
what do you mean?
if your in dos, to get back to windows (assuming you are windows95 or higher)
type exit I believe...
Discussion Starter #20
ill try that be back in a few
1 - 20 of 28 Posts
